Design of the Fluorescent Lamp Ballast circuit
omara007
Cairo/Egypt
Does anyone have a full design of the Fluorescent Lamp Ballast circuit ? .. schematics with discrete components and their values are very welcome :) .. PCB layout is welcome as well .. :wink:
Re: Ballast Circuit
International Rectifier and ST Microelectronics have some ICs for electronic ballast. Look at their sites and you will find a lot of application circuits and useful informations.
Re: Ballast Circuit
I don't know you are still interested or not, just post this file for you because I've lost the link to the original site. This is in Russian, but the schem is quite simple. If any question, just come back.
Re: Ballast Circuit
I made an electronic ballast recently with IR2153 and opto-triac/triac on-off switching with pic timer. When I use the circuit without the timer(off state) nothing happens as one would expect, but when I connect the timer(although it's in off state) it literally evaporated the copper from the triac to the rectifiers( with no load on the output). I'm currently out of ideas what to check, because I can't find the problem. Any help would be appreciated.
  • timer.pdf
  • timerbrd.pdf
