nehal02
Newbie
- Joined
- Jun 20, 2024
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 11
hi everyone,
while i was trying to simulate a hairpin bandpass filter in hfss i am getting this error message. Can anyone guide me how to solve this issue
hairpin_major1[1] (E:/)
HFSSDesign1 (DrivenModal)
[info] Discrete solution, process hf3d: '1' conductors touch lumped port '1', typically a lumped port contains 2 conductors. Please verify conducting boundaries and objects are correctly assigned and touch the port. If a Radiation boundary touches the port and it is desired for use during the port solution, select 'Use Radiation Boundary on Ports' under the Advanced tab in the Solution Setup. (7:13:24 PM Dec 28, 2024)
[info] Discrete solution, process hf3d: '1' conductors touch lumped port '2', typically a lumped port contains 2 conductors. Please verify conducting boundaries and objects are correctly assigned and touch the port. If a Radiation boundary touches the port and it is desired for use during the port solution, select 'Use Radiation Boundary on Ports' under the Advanced tab in the Solution Setup. (7:13:24 PM Dec 28, 2024)
