design of a hybrid fuel cell (battery and fuel cell) in simulink
cutiepie
Newbie level 3
Newbie level 3
hello ...
i m in dire need to design a hybrid system with fuel cell and battery in matlab. i dont know how to proceed.. can sum1 help me with some papers or links having basic info.. so that sum1 like me who knows nothing can proceed. Thank you.
What *aspect* of the hybrid system are you trying to design/model?
Are you trying to describe the charge/discharge state of the battery in response to finite fuel cell output and electrical system (=motor?) load?
Or are you describing the electrochemistry of the cell? Or the battery?
Or something else entirely? :)
If you're trying to create a big, complex model, what bits can you simplify/ignore/assume something about?
thank u for replying..
I m designing a hybrid system as a source for a microprocessor.. it should work at around 12 W power. i need to describe the discharge profile of the battery.
I want to purchase a Fuel cell which gives an fairly good output.Please do suggest me the sites where I could probably find the same. Alternatively if anyone could suggest a schematic or instructible on how to construct a fuel cell.
An idea on how much voltage I could get from one unit of this. And could I power this fuel cell from a solar panel...i need some idea on it...
I'm sorry what i meant was I needed to know how much output I could normally get from one Fuel cell unit.
I wanted to power it using a solar cell which has an output of 18 volts.
