design of 50Hz power transformer for full wave rectifier
Yasinji
output transformer design
How to design a pushpull inverter transformer for cfl ballast of 18W output power from 12V input voltage and 1.5A input current generating 50V cfl Von voltage and 360mA at the ouput. According to frequency, output power and input power how the high frequency ferrite core is selected. The inverter is switching in 33KHz. kindly help on how to design transformer? How to design the number of turns in primary and secondary winding? How is frequency related to transformer design. How the core is selected? and how the particular Al value of core is related to output power, current? how the transformer saturates? How can we know that a particular core will not saturate if used for the above application :?::?::?::?::?:
try this
the sec is not center taped
inverter transformer design
rajudp
i want to use transformer design program
plz give me
thk a lot
i want to design tranformer input 12 VDC to 380 VDC 2 A freq 30 kHz push pull
transformer design
380v 2A 760W i dont think you can drive with normal core need AP of the core arount 46sq cm.
what core you are planning to use . if you increase the frequency then it is possible
inverter+transformer design
I think you want made lamp driver ..
try this https://ludens.cl/Electron/Fluolamp/fluolamp.html
