What do you mean half ground plane? On IE3D, you can define infinite ground on substrate or you can define finite ground plane using some polygons. If it is semi-infinite ground, you need to use finite ground to model it. You just add some polygons to represent the finite ground. Then, you make sure your ports are localized ports referencing the finite ground.
