Design differental impedance match circuits
memphise
Junior Member level 1
Anybody can tell me how to design differental impedance match circuits?
Thanks in advance! :roll:
I suppose you require to match the differential I/Os of the IC.
Take the Total Impedance (1K differential on each arm => 2K total) and match as you would for single ended. Split this into differential by halving the series impedance and doubling the shunt impedance. This proced ure works well for filters and I hope it works for matching as well.
impedance matching
There is a very good tutorialon the data sheet of the IC AD8306 from ANALOG DEVICES. Look there.
Mandi
Re: impedance matching
Mandi
Can you located the files from Analog Device ? I haven't find it. I also long search a professional and success method to match impedance at about 2GHz.
Best rgs
Rayengine:I downloaded the file from Analog Devices,the datasheet of AD8306.
Many thanks to all
memphise
Also check out P/h/i/l/i/p/s app note A/N/1/7/7/7. It has a good discussion on differential mixer matching. I use this all the time. I measure the differential impedance, put the S-parameters in @DS, do the match, solder the parts and then tweak the values.
Have a look at www.pcbstandards.com site articles.
Also www.pcdmag.com had an article in March99 issue title, "Terminating Differential Signals on PCBs" written by Steve Kaufer & Kellee Crisafulli.
I cannot find the PDF version of the article but I have hardcopy version.
Here is the article I mentioned
Could someone tell me the difference between Single-End & Differential?
Single ended is when there is just one conductor and ground. Differential is where there are two conductors and ground. The differential signal voltage is the difference in voltage between the two conductors. The common mode signal voltage (which is desirably zero) is the average voltage of the two wires compared to ground.
u can get it in the following file
Any practical references for so-called adaptive impedence matching?
"Differential Impedance" from UltraCAD is a good article for you.
Here is an Article about S-Parameter!
