design compiler tcl mode 's error
zzczx
Junior Member level 3
hi members,there are such errors when I invoke the dc_vision -tclmode.
What should I do to eliminate the errors? thanks
Error: Cannot create procedure named 'group_variable' - existing command
Use error_info for more info. (CMD-013)
Error: Procedure 'group_variable' cannot be modified. (CMD-051)
Error: ::group_variable
Error: Cannot create procedure named 'print_variable_group' - existing command
Error: Procedure 'print_variable_group' cannot be modified. (CMD-051)
Error: ::print_variable_group
Error: Cannot create procedure named 'read_verilog' - existing command
Error: Procedure 'read_verilog' cannot be modified. (CMD-051)
Error: ::read_verilog
Error: Cannot create procedure named 'read_vhdl' - existing command
Error: Procedure 'read_vhdl' cannot be modified. (CMD-051)
Error: ::read_vhdl
Error: Cannot create procedure named 'read_db' - existing command
Error: Procedure 'read_db' cannot be modified. (CMD-051)
Error: ::read_db
Error: Cannot create procedure named 'read_edif' - existing command
Error: Procedure 'read_edif' cannot be modified. (CMD-051)
Error: ::read_edif
None meets the same question?
Could anyone give a suggetion?
