design chart alarme system
buhafsaek
Member level 1
Member level 1
intruder alarm john becker
we search a chart to design an alarm sytem for home intrusion motion etc with microcontroller like 16f877
Try:
1. EPE Magazine April 2002 - "PIC [PIC16F877] Controlled Intruder Alarm by John Becker - A sophisticated multi-zone intruder detection system that offers deluxe monitoring facilities."
2. Elektor January 2004 - "Burglar Alarm
This is a circuit of a simple but effective burglar alarm, which shows the status of each sensor with a separate LED. This allows you to see at a glance whether any doors or windows aren’t closed properly before switching the alarm on." (8051-type)
Cheers,
FoxyRick.
Hi
For the elektor issue you have to check the paper article, try with the library. The PCB can be either be bought or download the PDF. I do not know if they sell issues that new. More info can be found at elektor-electronics.co.uk/
For EPE you can check their homepage ttt.epemag.com/ for their projects, I guess someone can help you with a PDF for the project.
I can see if I can find the EPE article for you, if you do not see it here soon, PM me :)
There are also other projects here , search the forum.
Good luck
Cl
