Design and construction of a system identifying N2 nad H2O
adwnis123
Full Member level 4
Full Member level 4
I have read papers that use LIDAR-like and LIDAR-Raman systems that detect elements.
I want to measure the vapor water (H2O) and N2 of trees/agriculture using Arduino and low cost elements (DIY).
I am thinking of using 405 nm 500 mW laser. The problem is how can I detect the returned wavelength?
What I am thinking:
1) A CCD sensor?
2) A Photodiode array?
3) A modified webcam?
4) A photodiode with a filter?
My question is what do I measure with the wavelength sensor? The time from when I send the pulse of the laser and the time it returns in the wavelength sensor? Only the wavelength? Should I send a specific coded message with the laser? For example 101010011 ?
Thank you
