Design Analyzer Error (RH 7.3, DA 2003.06)
Bajaj
Junior Member level 3
When I try to read verilog or vhdl files i am getting following error
Initializing...
Error id=489925
Fatal: Internal system error, cannot recover.
I am using redhat linux 7.3, design analyzer version 2003.06
What is the solution??
Thanks in advance :):):)
seems you can read with command mode instead of GUI
I have the same prob....... :?
2003.03 works with RH9
Hello fiber7
Is 2003.06 works with RH 9.0??
Hi, Its working perfectly on redhat 8. I never had a problem.
Regards.............
