design a op amp with 2Vdd or 4Vdd of output voltage
red_0220
Junior Member level 1
design a op amp
Hi all,
I plan to design a op amp , and I have a power supply(Vdd) is 5V.
How can I design a op amp with 2Vdd or 4Vdd of output voltage?
design a op amp
You have to have a boost converter or charge pump of some
sort. Or, you forget about the 5V supply and use some
other resource of appropriate voltage.
    red_0220
Re: design a op amp
red_0220 said:
Hi all,
Do you want to limit the output voltage from the opamp?
