Depth sensor with microcontroller
GURMEET singh
Junior Member level 2
I want to make a robo car which will sense the depth and move accordingly to different direction.But i dont know about depth sensors Please through a flood of light on depth sensor and how it can be interfaced with Microcontroller(pic16f)
if you mean distance and proximity sensors, so you can use ultrasonic sensors or laser sensors.
you can buy them as separate modules then download the appropriate interfacing library.
take a look here
http://www.micro-examples.com/public/microex-navig/doc/090-ultrasonic-ranger.html
http://www.adafruit.com/product/164
http://www.sparkfun.com/categories/84
http://zuff.info/RangeFindersComp_E.html
http://www.digikey.com/product-search/en/sensors-transducers/proximity-sensors/1966557
good luck and inform us with results
yeah sure!!
what is the number of ultrasonic sensor?
I mean how i will ask to the seller for ultrasonic sensor?
yeah sure!!
An ultrasonic sensor in characterized by its working frequency.
Almost all these sensors work between 30Khz to 40Khz and the range of distance is around few meters.
Check the websites i gave you for more information and try to get used with reading datasheets.
