[SOLVED] Delta Vbe current mirror and BJT question
AMSA84
Advanced Member level 2
Iberian Peninsula
Hi guys,
I am designing a delta vbe current reference with a PTAT and CTAT current current references that will be summed out.
The question I want to ask is the following: Since the CTAT current reference has only 1 BJT and the PTAT current reference has 1 BJT + 8 BJT, can I use the same node from the 1 BJT voltage from the PTAT current reference into the 1 BJT CTAT current reference, instead of using one more BJT in that current reference (CTAT)? This way I would stay only with one matrix 3x3 and not with 3x3 + 1.
I don't know if there are some implications doing this.
Regards. Thanks in advance.
You shouldn't do this. Why? Because your original current ratio of 1:8 is gone, and I doubt it will be easy to get a good compensation.
If yo want to stay with a 3x3 array, you'd better reduce the 1:8 ratio to a 1:7 ratio. Remember you can use any ratio, just the relation between lnA (A=ratio) and the resistor ratio must be correct.
If you mean hanging another base off the {1X, 8X+res} base
node, I think the question becomes about the excess base
current, where it comes from and what it costs (e.g. more
curvature / low temp deflection). Without a schematic to
look at I can only speculate broadly.
Since references only are used 1X or few-X per chip, is
optimizing layout area and array size really a big deal?
It's not like squeezing square microns out of a DFF that's
going to be used thousands of times. I think this is more
about quality of the reference than gross area etc. And
what specifically is wrong about a 4x4, 1:14+1 array
other than square microns again? More local current gain is
not often a bad idea, helping some with PSRR and startup.
