delta sigma simulation, MATLAB vs. Verilog A
jowong1
Junior Member level 1
matlab delta sigma
I have a confusion involves the SNR comparison of DSM simulated in MATLAB and VA. In MATLAB, I can get the theoretical maximum SNR (88dB) using transfer function blocks and quantizer block. But in VA, it gave me 68dB (I used the laplace transfer function in VA to create my loop filters, and quantizers and DAC are 16 levels). I don't understand why they don't match since I don't have any non-idealities in my VA models.
Thanks
delta sigma verilog
Maybe simulation settings like reltol, abstol ,etc
matlab verilog
how is it possible that those settings are enuf to chop 20dB off!?!?
Thanks
function sigma matlab
matlab is better and it has toolsbox
matlab verilog a
ya but i wanna model some non-idealities which MATLAB cannot do......
delta-sigma verilog
you can model non-idealities like clock jitters and limited opamp gain using SDToolbox
sigma in matlab
Matlab error is simple 64bit IEEE-754 numeric. If you use some functions in matlab the error control is "eps"
type eps=2.22e-16
That is typical much tighther than what simulator implement. But set reltol to eps of matlab could fail because most spice relevant models are calculated in 64bit floating point but sometimes with hard coded accuracy or the numerical presiscion is lost by some orders by the implicite routines. So failure in convergence is the result.
