Delta sigma ADC transient simulation in Spectre
jowong1
Junior Member level 1
zero diagonal found in jacobian
I am running into a problem when I was trying to simulate my DSADC in spectre. The entire system is using ideal components (no transistors, but there are VCVS, R, C) and Verilog models. When I was doing transient sim using "Liberal" setting, for about 60us, it was running fine and giving correct output (noise shaping and all that) but then at about 60us, all of a suddent, there is a "Zero diagonal found in Jacobian at XXXX net and YYYY net". and then the output starts to just oscillate and I cannot figure out why.
One more thing is that my ADC will work ONLY IF I do the transient in "Liberal" setting, if I try to do it in "moderate" or "conservative", then it wont work at all (The output just stays at a constant voltage).
I was wondering if anyone out there can help me with this.......
Thanks
zero diagonal found in jacobian at
Maybe, the components are too ideal. For example, input impedance is infinite, output impedance is zero...
