delphi, cbuilder or vc++ or c#
elecomp
Newbie level 5
Newbie level 5
I want to compare these four: delphi, cbuilder, vc++ and c#
which one is better for
1. being fast(my application should be realtime)
2. being easy to program
3. having ready sample codes on the internet
thanks for any help
hi,
being fast
1) VC++
2) delphi, cbuilder
3) c#
1) c#
2) delphi, cbuilder
3) VC++
having sample code on the internet
1) c#, has a lot of backing from microsoft and hence a lot of samples
2) vc++, a majority of c++ on windows program using vc++ and hence a lot of sample code is around the net
3) delphi,cbuilder
hope it helps
    elecomp
VC++
C#
VC++
--- My Favorite PC's interface Hardware ---
http://www.thaiio.com
Thank you
it was helpful
But, are you sure C# is easier than Delphi/CBuilder?
I've not programmed with C#, but Delphi and CBuilder are very easy to program.
I think Delphi is easier to learn than C#.C# has a C style syntax and is somehow difficult.
what do you mean with realtime?
If you are going to run realtime application on a Windows machine , I would suggest VC++. There are a lot of examles on the internet.
If you choose VC++ or C# you will find alot of help at **broken link removed**
/Magnus
C++ is Fast But C# is power full And Reliable And fastest in all is Python
thanks for any help
1. being fast:
VC++, VC++ and VC++ :D
For the fastest code you have to use VC++ end of story.
2. being easy to program:
C# and Delphi
3. having ready sample codes on the internet:
VC++, Delphi and a little (but growing every day) C#
Forget BCB
hi
I think *** Delphi *** is very easy to pgm.
than cbuilder, vc++ and c#
