xmas111
Newbie level 5
Hi everyone,
I'm working on a DELL ALL IN ONE computer (Model 2035) for a friend. The display was dead.
After opening it up I found a SMD resistor laying inside. It had broken off the Converter Board.
At first I figured it was a lousy soldering job and it just broke loose. I soldered it back on and the display came on. Well that was a easy fix I thought then a minute later it shut down again.
As it turns out the SMD resistor ( I'm pretty sure it's a resistor) had gotten so hot it melted the solder joints and fell back off! I've never seen this before.
Anyway, wondering if you guys might have any suggestions what might be causing the problem.
Attached is a picture of the board with the SMD Resistor that fell of circled in red.
I know this is a pretty vague question and haven't given a lot of information but do you think it could be something on the board causing the problem or something else altogether.
I can get the replacement board for $7.00 and give it a shot but don't want to waste my time if something else is more than likely the problem.
All I can see on the resistor is the numbers 100 and 1116. Is 100 the resistance value and 1116 a manufacturing date.
Thanks guys,
John
Thanks guys,
John
