Delayed power / flip circuit help
markponikvar
Newbie level 1
Newbie level 1
Here is what I am trying to do:
The +12VDC can be switched on or off.
If the +12VDC is off, then output 1 and output 2 should be 0.
If the +12VDC is turned on, output 2 puts out +12VDC, and output 1 is 0. Around 20 seconds later, they switch, so that output 2 goes to 0 and output 1 goes to +12VDC.
R1 = 19 turn 1K pot (used for changing the timing delay for the switchover, not sure if 1K is the correct value)
D1 = 1N4002, should cause a 0.7V drop or so.
C1 = electrolytic cap (+ up, couldn't find the right symbol), 2000uF 25VDC
Q1 = transistor (no clue which one to use)
U1A = bus (no clue which one to use)
Only additional caviat are that the outputs will each need to be able to drive a relay. I am not sure what else I would need after this.
Thanks for all the help... been over 10 years since I played with circuit design :(
Mark
