Define boundary condition in CST for circular patch antenna
zhiweisim
Junior Member level 3
May I know how can I define the correct boundary condition for a circular patch antenna which has a circular ground plane? Here are my settings:
ymin, ymax= open
xmin, xmax = open
zmin = Et=0, zmax = open (added)
After setting up the boundary conditions, a boundary box can be seen. When I try to run the simulation, I get this error:
Inhomogeneous material at open boundary detected (The structure must be identical in the open boundary plane and the next two mesh steps)
Location(s): xmin xmax ymin ymax
I believe this error is due to the air meterial located at four edges of the box (since the ground plane is circular shape). therefore, may I know how to fix this? Please help. Thanks.
inhomogeneous material at open boundary detected
Can you send some picture from CST ?
adaptive mesh refinement cst
Hi zhiweisim
use open (add space) boundary condition for all directions and hopefully your problem will be resolved
regards
shahid
    zhiweisim
cst background material
hi shahid/mauloftin,
Attached is the boundary condition box of my circular patch antenna. I tried both methods, using
1) open for xmin, xmax, ymin, ymax
(by setting surrounding space for the background material)
lower x distance, upper x distance = 1cm
lower y distance, upper y distance = 1cm
2) open (add space) for xmin, xmax, ymin, ymax
and I get two different minimum S11 values (resonant frequencies), one being 867MHz and another one being 868MHz.
May I know which method is correct in setting up the boundary conditions?
Thanks.
cst open boundary
As you can see from the attached S11_all three cases.jpg result below, I got three different S11 values at one particular frequency when using three different boundary condition settings:
1) open
(1cm surrounding space for background material for xmin, xmax,ymin, ymax)
zmin = et=0, zmax =open added
2) open
(0.5cm surrounding space for background material for xmin,xmax,ymin,ymax) zmin = et =0, zmax = open added
3) open (added) (for xmin,xmax,ymin,ymax)
4) Also I did play around with the boundary condition settings where I set all directions as open added (xmin, xmax,ymin,ymax,zmin, zmax) and I did get a much smaller S11 values with different resonant frequency at 866MHz. Please see 'S11_all direction open added.jpg'.
Therefore, may I know which one is the correct approach? Which one is more accurate in getting the S11 values as well as the radiation pattern? I am getting a bit confused.
cst 1% circular latest
So,
first: use xmin, xmax, ymin, ymax open (add space), not only open, I think that is better.
second: 867 MHz is for set 1) and 868 for set 2) ? It is OK, CST is not absolutely precise :D, 1 MHz is not accuracy. Now you must use "Adaptive mesh refinement", is it in "Transient solver parameters". Try it and wait, you can see, that the resonant frequency will be jumping (you can see in Navigation tree - 1D results - Adaptive Meshing - S [dB])
I hope, that I helped you
Added after 6 minutes:
btw CST help:
Open: Operates like free space. It is available for the electrostatic magnetostatic and thermal solver.
Open (add space lf): Similar to the open boundary condition, with some extra space added between structure and applied boundary condition.
Added after 4 minutes:
and 2. btw:
try in help search: Circular Patch Antenna, it is
third result, there is inspiration for you :D
cst background material edaboard
Hi again,
I have something for you. It is about CST and boundary - is it in attachment, page 7.
  • cst_application_note__antenna_3778.pdf
cst boundary condition
Hi zhiweisim
In the Help of the CST, analysis of circualr patch had been discussed.
good luck
define cst @ 4% extra ?
hi
the example of circular patch antenna in CSt help is different in the sense that it has rectangular ground plane. while the person who posted this question has circular ground plane . so he cant use open boundary condition without introducing some additional space or using open (add) boundary conditions.
in my view rather than manually adding surruonding background space its best to use the opne(Add) boundary conditons for good results
i hope this helps
regards
setup antenna circula
Hi zhiweisim
regards
shahid
I agree that. You must set open (add space) boundary condition for all directions when your work is antenna.
(^_^)"
