@ CST library are spice par. Much better and accurate use like box s2p. Otherwise transistor is good and cheap, below 1$. Only for attention, exists not correct s par for these transistor. For example s21 grooving ( excitation in a dut )above 20GHz and so on. It should be monotone and logic curves. We made some device up to 40GHz.
