Decorder Snow: M505H
Lukas Dobihal
Newbie level 1
Newbie level 1
Hello! Since snow stops there service. I keep the decoder, I wondered if there would be away to flash the decoder. Its a Hybroad M505H
Specs : **broken link removed** )
This is a Linux 2.6 there is a 320GB HDD It has a Secure Boot and apparently HDD is under a Bitlocker impossible to read it. There would have a
way to bypass security to install XBMC on it right?
I tried to formate the HDD and put Ubuntu on it, and put it back to the decorder.
I can conclude that: The decoder doesn't boot on the HDD, you will get "snow" picture and few minute later, you will get a message to put internet
cable in. there must be an internal system and the decoder starts without HDD on the SNOW system)
I research more how to fix it, and i figure out that there are 2 connectors on the motherboard on the decoder is called "Debug" and another named
"BBS".
I put here some pictures, is it possible to explain me how to edite the Rom/bootloader/wich kabel?
Kind regards, Lukas
