Decoding MP3 with a controller w/out using any DSP just D/A
cwtech
Newbie level 1
Newbie level 1
Any one knows a simple doc how to decode MP3 files or how sound files are compress? (mp3 programming for dummies)
My plan was to dedicate a processor to decode an MP3 files without using any DSP just D/A.
Interfacing IDE with Printer Port
Re: Decoding MP3 with a controller w/out using any DSP just
Are you aware that there are MCU's with built-in MP3 decoder? For instance, the 89C51SND1C from Atmel (it's a good chip!). No DSP required, just hook it to a standard audio DAC, like the pcm1600 from Texas Instruments.
The Atmel chip has an IDE (hard disk) and MMC interface built in as well!
Just a thought...
Cheers,
FoxyRick
AFAIK an ARM7TDMI core running at about 70-75MHz and using very good quality software can merely decode 128kbps CBR MP3s. So using a CPU to do the decoding might not be the best idea in your case. I would check the many excellent MPEG decoder chips out there (my personal favourite is /VLSI1001/). Or, as FoxyRick said, use a MCU with an integrated decoder.
sources decoder MP3 an ARM7TDMI core
2bogdanm: Tell me please URL to an project with the sources of decoder MP3 an ARM7TDMI core.
Well, it seems that I was wrong and I apologize for this. I found somewhere a link to an MPEG decoder that can decode a 48khz/320kbps MP3 file on an ARM7TDMI core running at only 30MHz! Here is the link to the project:
/https://datatype.helixcommunity.org/mp3dec
So it becomes quite feasible to do this with an ARM! I apologize again for my previous erroneous statement.
Here is problems :(
Link to code: /https://datatype.helixcommunity.org/source/browse/datatype/mp3/codec/fixpt/
Page not found!
Maybe this helps:
/http://forms.helixcommunity.org/helixdnaclient/
bogdanm said:
Maybe this helps:
Here there are no sources for ARM core (fixed point) :(
