Debussy: How to specify top module file(.v)?
dd2001
Full Member level 4
Full Member level 4
debussy read verilog files
I first time use Debussy, and don't know how to specify top module verilog file when read design files(30 verilog .v files)
thanks
debussy virtual top file not
You don't need to specify top module verilog file.
Just Import Design from file( every .v or use .f), it's OK.
Hi, hgby2209:
Please check the menu under
File --> Import Design
Then you can find a space behind "Virtual Top". Place your top module name there.
Good Lucks,
Hi!! sandusty,
Is it really necessary to Place top module name in the "Virtual Top" ?
I use Debussy many times, but never place top module name in there, and it's work correctly and no error occurred.
If it works.... then I will just take it and use it... :)
