Debugging usin PICBASIC PRO
mtkee2003
Full Member level 2
hi
in some compilers like CodeVision or BASCOM we cun run the program line by line and step by step, so debugging the program is easy. i want to know that does PicBasic PRO support this capability?
in other word i want to debug Basic Codes line by line.
with best regards
hi blueroomelectronics
yes i know that MPLAB can debug PBP's Programs, but it can debug in Assembly not Basic.
i need a debugger in Basic
with best regards, Mostafa
proteus can do that just give try
regards
Fragrance
hi !!!
proteus can't do this job.
best regards
mtkee2003 said:
hi !!!
best regards
just read pic16 help file and then read topic debug format answer is there man proteus can do that i think you need some teaching
hi Fragrance.
thanks, i read the "PIC16 Microprocessor Model" document. proteus can support this High Level Languages:
IAR UBROF Loader
ByteCraft COD Loader
Hitech PICC and PICC Lite
Crownhill Proton Plus PIC BASIC compiler
but i want to debug programs that written with PIC BASIC PRO (from MELabs company Not Crownhill).
is it possible?
thanks in advance.
Yes it is with "MicroCode Studio Plus"...
Each line of source code is animated in the main editor window, showing you which program line is currently being executed by the host microcontroller. You can even toggle multiple breakpoints and step through your PICBASIC PRO™ code line by line.
The MicroCode Studio ICD communicates with the microcontroller using its hardware USART...
This project will introduce you to the MicroCode Studio In-Circuit Debugger with PIC16F628 :
http://www.rentron.com/PicBasic/MCS_X3.htm
    mtkee2003
hi hugo,
thanks, i have MicroCode Studio PLUS, but it seems that MicroCode Studio PLUS needs some special hardware for line by line debugging. when i work in KEIL or CodeVision they didn't need any hardware for debugging.
is there anyway to debug my program in PICBASIC PRO without any special hardware?
thanks in advance, Mostafa
when you want debug MicroCode Studio PLUS with Microchip pic , you must connect serial port ( TX, RX, GND ) from PIC MCU to PC.
"when i work in KEIL or CodeVision they didn't need any hardware for debugging." It is simulate ( not debug )
    mtkee2003
thus it is impossible to simulate PICBASIC PRO, programs? is it true? :|
best regards.
MPLAB SUPPORTS SINGLE STEP DEBUGGING with PICBASIC Pro.
You can OPTIONALLY look at the assembly code if you like.
    mtkee2003
HI
you can debug with a small hardware(max232) . loock in help
--in circuit debugger
--hardware setup
that is all .it is too simple to make this hardware
    mtkee2003
