katastic_voyage
The background:
So I have a Korg DW-6000 synthesizer that does not work.
- Analog synth (~6 polyphony) digitally controlled by a CPU and memory for programming the PM/FM chips.
- The internal PSU, so far as I can tell, works fine. (Fuse is fine!) It has 3x 5-volt rails, -5, 7, and 11-15v rail. Powered by 7805, 7905, etc IC's all mounted to the same thick heatsink electrically separated with a thin paper layer.
This thing is old. It's early 80's. Through-hole, fairly sparsely populated, modular boards. It shares my components with the DW-8000 synth (simply more polyphony.) So if you google images of either of those, it'll show up.
Now the problem:
- It does not turn on. It flashes '88' on all the LEDs and then immediately goes dark. I've read somewhere that means the CPU has turned on and successfully cleared a bit from the LED drivers. However, nothing happens after that.
- AND, "sometimes" it doesn't even do that. In fact, more often then not, if I flick the power on, it does nothing at all. (There is a pop at the headphone jack as it turns on.)
- The PSU rails come on. But THIS is where I'm really confused. I started plugging only a single board (of ~5 different ones) in at a time. When I got to the CPU board >>the voltage goes from 5-volts to 4-volts<<. Sometimes even 3.9v.
- The resistance between ground and power plane with just the board (no PSU connected) is ~400 ohms. That doesn't seem too low. But I don't know if that's a real diagnostic method.
- The capacitors are all 1980's old. Many ceramic, and some aluminum/can ones. But I don't see any bulges on them.
- I haven't seen any cracked solder joints but I don't have a lot of experience looking for them.
---> ALSO, I have a cheap soldering station with integrated PSU. So I put 5 volts into the board myself (to see if the Korg PSU is faulty). I had to raise it to 5.6 volts to get 5.0 volts at the connector. And that's really confusing to me. I measured with both a multimeter and the solder-PSU's analog current meter, and both say it's about ~0.6 amps. 0.6 amps doesn't seem like a lot. So why would I get 5.0 volts at a connector where I feed the voltage in when running 5.6 volts from a supply? Is 0.6 volts being eating in the wires themselves? Something doesn't add up here. How can I lose 0.6 volts.
---> ALSO, I have a cheap'ish thermal camera which has very poor lens for close up work but from the globs, I can tell 5 chips are warming up. But, they're not warming up much at all. After ~10 minutes they're maybe 90-100 F. The CPU, and 4 SNxxxxxx chips. But I can't tell if that's normal because the board isn't fully powered up, or, if those 5 chips actually indicate a failure mode.
From what I can tell, before I can use this board again, I have to reload the patches into RAM by using a "tape" port (audio in jack). And I believe I found those. However, I don't believe that's the error here because, I believe, the display should power up with an error code that indicates the memory/patches are missing, and respond to button presses.
I know this synth (and synths in general) are an esoteric niche to ask about but the one thing that I know falls into general ECE field, is that strange 0.6v voltage drop.
Thank you in advance, any advice into figuring out this thing would be greatly appreciated.
Now the problem:
