Debugging program on Atmel AT40008 in ADS 1.2
nust10
Junior Member level 1
about arm
When using ADS1.2 to debug program. The program in memory is be overlapped duing ececuting progress.
The chip is atmel's at40008, RO BASE is 0x0000, and RM is automatically set by ADS . I only use at40008's inner memory without outer memory. The startup file is from atmel, and I don't modify it.
Thanks
about arm
If at40008 isn't remapped, the address 0x0000 is read-only.
The startup file for ICE and flash is different.
