bobdxcool
Member level 5
I have a sugar cube relay which I am using with my controller. It turns On/Off when high or low signals are sent from the microcontroller. It can take upto 240V AC at 10 amps. The way the relay circuit board is that I connect the positive and negative of DC or AC Line and neutral at the input terminals, I get the positive and negative DC at the output terminal blocks or line and neutral at the output terminal blocks When I connected 120V AC Line and neutral wires at the input terminals of the relay, at the output I am only getting 12V AC. What could possibly the reason for this ? Is the relay broken ? It was working fine a few days ago.
