I have taken over a partially completed DDR4 design. I'm somewhat suspicious regarding corners that is bent more than 90 degrees as seen in the picture. I'm aware that 90 degree corners should be fine below a few GHz.
the design rules are hardly used, not even length constraints are set up, except diff pairs that have 0.1mm tolerance. Obviously it's designed w/o xSignals...
