speedster
Newbie level 1
Hello,
I'm looking into datasheet of DDR2 from Micron https://www.micron.com/parts/dram/ddr2-sdram/mt47h64m16hr-187e. If you see functional diagrams on pages 12-14, there is Column address COL0, COL1 (2 LSBs) going into 4n-prefetch directly. They're not going into column address decoder.
Now my concern is:
This only means we can burst only the "pre-defined" 4n chunk, i.e., from 00,01,10,11 LSBs.
So for example if I needed to burst read 4-data chunks (x4, x8, or x16 bit wide) from current active row, with following column address:
0000 1010 to 0000 1101 (Assuming 8-bit column address for simplicity)
, then its not possible in single burst because the column address decoder is ignoring the 2 LSBs in functional diagram when it is taking the starting column address. 4n-prefetch is automatically assuming the two LSBs to be 00, 01, 10, 11 (in that order).
In other words, the _starting_ column address from 3rd LSB up to MSB is assumed "same" for the burst.
In my example case, the 3rd LSB is changing from 0 to 1 (2 data chunks with 3rd address bit 0, two data chunks with 3rd address bit 1).
In my above example, I'd have to burst read _two_ 4n chunks. One 4n chunk from
0000 1000 to 0000 1011 (ignore first two chunks, 0000 1000 and 0000 1001)
_and_ second 4n chunk from:
0000 1100 to 0000 1111 (ignore last two chunks, 0000 1110 and 0000 1111)
i.e.,
first burst:
0000 1000 (ignore)
0000 1001 (ignore)
0000 1010 (valid)
0000 1011 (valid)
second burst:
0000 1100 (valid)
0000 1101 (valid)
0000 1110 (ignore)
0000 1111 (ignore)
....in order to get data from 0000 1010 to 0000 1101.
So the data chunks/ bursts are 'aligned' already for us. We can only specify the starting column address to be uniform from 3rd LSB upto MSB. And 2 LSBs are automatically assumed to be in order 00, 01, 10, 11.
Is my understanding of the burst alignment issue correct? Please comment.
Now my concern is:
i.e.,
first burst:
0000 1000 (ignore)
0000 1001 (ignore)
0000 1010 (valid)
0000 1011 (valid)
second burst:
0000 1100 (valid)
0000 1101 (valid)
0000 1110 (ignore)
0000 1111 (ignore)
