ctzof
Full Member level 3
Hallo,
Maybe this is a simple question but I want to be sure. I want to design a common mode filter for the input stage of a DCDC converter (200w input). I follow this application **broken link removed** where they suggest the filter in figure 1. The input of The converter is a dc voltage which means that VIN- is ground in hat case. Then what I should do with the capacitor C_in4. The upper leg is connected to gnd so for the lower leg I have 3 options
1. Connected to gnd
2. Connected only to the lower right leg of the common mode choke
3. forget about C_in3 and C_in4 and place a capacitor with a value which is double the value of C_in4.
Which of them is the correct?
1. Connected to gnd
