shaneelal
Member level 1
voltage sensor site:www.edaboard.com -search
I"m building a device that senses both current and voltage and displays result. I"m using a PIC18F452.I"m supposed to sense the current and voltage every 2sec
Should I use two channels on the PIC,one for each sensor to perform ADC? Or should I use an analogue multilpexer?
I"m looking for a dc voltage sensor which can sense atleast 0-50V,prefferably one that has a range of 0-100V .
Specifications required:
Voltage Range 0 - 100 volts
Relative Precision of Range ±1%
Max Linearity Error ± 0.5 % of reading
Band Width at ±1db 2.5 Khz
The one I'm looking for is found in this device Micro ADM™ Micro Arc Data Monitor.
Website - **broken link removed**
manual at https://www.cweldtech.com/Manuals/MicroAdm-Manual.pdf
Does anyone know the sensor they used or a similiar one?
Your help will be greatly appreciated.
