DC voltage & current booster
johny_ulau
Newbie level 5
Newbie level 5
Malaysia
hi all,
anyone know how to boost dc current from 6V to 12V with current limit is 25A..?
your question does not make alot of sense.
You cannot boost both the voltage and current.
For example
If your 6V supply is capable of delivering 25AMPS - that is 150 Watts
Power = Volts X Current
if you boost the said voltage to 12V, assuming 100% efficiency! the current available will only be 12.5AMPS.
In practice it is possible to get a voltage converter of ~95% efficient at a specified load,$$$, though more common efficiency would be 50-60% for less $
search "DCDC converters" for more information
Perhaps you should explain what your trying to do?
tQ for ur ans..
let me explain it.
i am try to use dc motor to charge the car battery 12V.
when the motor rotates, its supply 6V & 1AMPS..
so is it possible to step-up the voltage and current?
Hi Johny,
As Xaccto wrote, you can boost voltage or current tto, but not at same time becouse you can not produce through boosting more energie!
Typical DC/DC converter has an efficiency of ~70-80%, means if you double the voltage _your corrent cant more as 50%multiplyed with 0.75 (efficiency) the 1A (at6V),also your 12 V current wiil be maximum 0.35-0.4A!!
K.
tQ for answer..
so does it's mean that if i gain voltage, the current will step-down?
but if i step-up only the current, does it will step-down the voltage?
Exactly, tha the "product" UxI=constant! (& of course minus efficiency), also power/=(UxI)xη ...
η=0.7--0.9 (in best cases).
K.
Your welcome.
Energie/power input = voltage in(U) x current in(I) , after converting;
Energie/power output= voltage out(U) x current out(I) but Input power is not more & not equal with output power!
You have to calculate with conversion efficiency(η) too, where (η) is garanted less as 1! Means, after some conversion, you will have still less energie/power product ...
K.
owh!..
example; let say i has a car alternator, charge 12V 45A.
if i boost a voltage to 24V, the current will be 20.25A. am i right?
Yes, maybe at 20A or less...
regards
K.
owh!
tQ..
i am try to convert 12V 6A to 24V... so i will get less than 3A. am i right?
erm, if i want only step-up the current, what circuit i need?
Jea, step up the current means: you can have only a "(voltage)step-down"-converter :-(... Its life.
K.
Jea, step up the current means: you can have only a "(voltage)step-down"-converter Sad... Its life.
K.
owh!
tQ
erm,, does its same like voltage converter?
lets say i has battery 12V 12A, if i step-up current double, does its step-down voltage double? so its result be 6V 24A?
So is it; tels us the equation from "10 Mar 2010 17:27" too...Dont forget to calculate with conversion efficiency(η), what is never=1 (100%), as said typically at 0.7--0.9 (70-90%), but can be lower too :-(...
K.
ok.
erm..
could you tell me where to find simple circuit of current step-up or how to make its circuit?
thank you..
Search pls for step down voltage regulators!
As detailed explained, their are the (from you) so called Current Step-Up Converters...
K.
