ballimo
Member level 3
Hello All,
I want to use a DC TO DC converter to supply 3.3V for a high speed design, usually I put a linear regulator (LDO) after the DC to DC converter, but in this case this is not possible because I will exceed the power budget.
I find two DC to DC converter with an output voltage of 3.3V and the required current rating ...., but one has a switching frequency of 0.5 MHz the other 2 MHz.
My question: is it better to use 0.5 MHz or 2 MHz as switching frequency for this high speed design? I know that with a proper filtering I we can reduce the output AC ripple, but does this mean that the filtering is the most important not the switching frequency?
Thanks,
Ballimo
Thanks,
Ballimo
