Hesambook
Full Member level 2
Schematic and PCB have been designed using Altium Designer 24. The PCB board has been tested against output voltage stability, temperature stress, and output noise using Siglent SDL1020X-E DC load, VEVOR SC240M thermal imaging camera, and Siglent SDS1104X-E oscilloscope. The PCB layout of the converter was designed with several precautions such as implementing power planes, low EMI, VIAs, and low ground path impedance. The input connector is a 5A USB Type-C, which makes it suitable for nowadays portable applications.
