DC Sweep in Cadence by using Parameters as ranges?
karsten_78
Newbie level 3
Newbie level 3
Hello,
I'm usung Cadence Virtuoso ADE and want to perform several DC Sweeps with different supply voltages (VDD). During these simulations another parameter needs to be swept from 0V to VDD (but not exceed VDD). Is it possible to define the max value for the DC sweep range as a parameter named VDD? And if so - how can I do it?
Thanks for your help in advance!
Karsten
Hi.
As I know, this is possible only in Cadence IC6. You must define design variable VDD, than in the field "Stop" enter VAR("VDD").
Hello dedalus,
I'm using Cadence 5. So it seems the simulations I want to run are not possible.
Thank you anyway.
If anybody has an idea, it will be very welcome.
Kind regards,
Karsten
