DC question about "set_dont_touch" command
sree205
Advanced Member level 1
Hi all,
i've a question regarding one of the design compiler commands. "set_dont_touch".
its used to make sure that some of the cells in the library are not used for synthesis. can anybody suggest why some cells should not be considered ? i can think of one options, but, am not sure of other options.
1. large fanout cells, probably not necessary for low gate count design.
if anybody has any other ideas, please share.
DC question
You are misunderstand "set_dont_touch" with "set_dont_use".
"set_dont_touch" is some hard mirco or clock you don't want synthesis tool to change it.
"set_dont_use" is not to use certain cells.
Re: DC question
avoid LATCH, for sync design.
DC question
love2read, yes, u r right. it should've been set_dont_use.
Re: DC question
i think not all cells in target library can be use for synthesis, especially for synchronous synthesis, for example, latch should be set_not_use.
a designer should have a clear understanding on cells' usage in lib to obtain a excellent implementation.
DC question
set_dont_use : avoid buf for clock trees in circuit.
DC question
hi all,
we use the set_dont_use command to avoid those cells which we dont want to use in the synthesis.
1.the high strength cells(X16,XL etc).bcz they will consume high power and some more porblem with those cells in the p&r.
2.the clock buffer/inv.bcz they will be used while building the clock tree.
3.some tristate cells and latches .they will be used according to the requirement.
4.jkflops,sr-flops.they will be used according to the requrement.
regards,
rameshs
