HINDI
Member level 3
- Joined
- May 1, 2004
- Messages
- 56
- Helped
- 2
- Reputation
- 4
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- MISR "EGYPT"
- Activity points
- 622
Hi all
there is a nearly 4Vdc offset in the signal that drives the high side in my H-bridge
and i don't know how to remove it .
i didn't have this problem when i was driving the motor with a high side switch only
i added a RC snubber circuit across the drain and source and every thing was working well i.e no offset ,sharp on/off , no distorion in either the gate or the source signal and the voltage diffrence between the gate and source are nearly above 12 v .
but when i have entered the motor between high and low side switches , a dc offset appears on the gate of the driver of the high side , so the mosfet turn off partially .
and the switching signal across the low side drain is distorted although the gate switching signal of the low side is nearly perfect .
i think it is the miller effect that caused this shift in the high side source and distortion in the low side drain.
but how to compansate miller effect ?
salam
hindi
salam
hindi
