Harry.f123
Newbie level 2
Hello,
I have a few questions which I cannot be sure I'm calculating right.
Here is what I have:
Motor speed 500rpm
Back emf 115v
Supply voltage 200v
Motor torque 40nm
I have to work out..
Armature current drawn
Armature resistance
Shaft power
What would be the rpm if the torque increased to 60nm
I have calculated
18.21amp
275.57mOhms
2.8HP
And by ratio 333rpm as I do not have flux.
All assuming 100 percent efficiency.
Can anyone find fault with my answers??
Motor speed 500rpm
Back emf 115v
Supply voltage 200v
Motor torque 40nm
Armature resistance
Shaft power
I have calculated
18.21amp
275.57mOhms
2.8HP
