DC Motor Controller
Rock Doctor
Newbie
Newbie level 1
Greetings. I am out of my depth trying to adjust my solar water pump to a lower rate. Not sure I need a brushless controller or a brush controller…and more importantly the specs of a controller that I need. HELP!!
My motor is as follows.
24V brushless motor submersible water pump
1/3 hp
Internal controller
Typical operating current is 10-11.00A.
The stall current is around 12.00A.
The pump can start around 150W. Max power is 250W
Only has two wires to the pump. Positive and Negative.
I need to dial the rate down almost 75% to the appropriate pump rate.
Write your reply...
LaTeX Commands Quick-Menu:
