yassin.kraouch
Advanced Member level 2
have you an idea on a current sensor that can measure up to 200A, and is not mounted on the PCB?? i found ACS758 but i can mount it on the PCB, i want on that can be mounted on the wire that support 200A ???
Define "low cost." You're not going to get anything for a few dollars. Off the shelf sensors will be in the range of $10-$50, at least. You could try making your own, but getting robustness and decent accuracy will probably be difficult.yes it is DC and the current is about 200Amp, have you an idea of a low cost current sensor
