DC Hall Effect Voltage Sensor
Hi Edda Fam
Anyone who has worked with Voltage sensor before please give some info on it, if you've worked on them before.
Nothing special, its just as current Hall sensors but voltage output represent voltage not current.
See one sensor as example :
Hall Effect Voltage Sensor CYHVS500T
http://www.hallsensors.de/CYHVS500T.pdf
Best regards,
Peter
You also find a number of hall effect voltage transducers from www.lem.com
Technically they are made as (compensating) closed loop hall sensors with many primary turns and a precision measurement resistor.
Reactions: tpetar
    tpetar
