DC/DC setp-up- sensor 0.3Volts, want to change power
filjoa
Member level 4
Member level 4
setp up
Hi
I like try make a little project where I have an sensor where I have only 0.3Volts and very little current, but I like up this power to +-1Volt
some one have some ideia how I can make some like that?
kind regards
0.4v boot up|step up
Do you want to make a voltage signal from this little sensor current?
0.3v dc-dc
wont be able to do anything with 0.3v
you need at least 0.6v to activate any semiconductor device that will start your step up...
setp up 2
ok
so if I have 0.6V but with little current. how I can step-up it to 1V?
DC/DC setp-up
A self oscillating converter based on a depletion FET would be also possible at 0.3 V, or use a germanium BJT. Without input and output current specifications, all suggestions have to be vague, however. What do you consider little current?
Re: DC/DC setp-up
Hi
FvM:
little current I don´t know but monday I tell you.
you can make and diagram with you tell me? used depletion FET ou germanium BJT?
Re: DC/DC setp-up
hi
sorry for my timeout.
this project consist in with an optical diode receptor where I have 0.3V/0.4V with +-70mW step-up it to 3.3V with +-10mA.
My idea is use MAX1709 because efficiency is good but it only work after have 0.7V or more, and because that I like step-up my 0.3V/0.4V to +-1V
Someone have an suggestion?
kind regards
Re: DC/DC setp-up
What about using op-amps to amplify the signal ?
Instrumentation op-amps also can do the trick
Re: DC/DC setp-up
I don´t have more than 0.3V/70mW in circuit... for I use opamps I need external Vcc and I don´t anythink.
DC/DC setp-up
simply confusing!
what is stepping up to +"-" 1V ??
what is that you want to do alltogether??
Re: DC/DC setp-up
(+-) =>> more a less
I don´t tell positive or negative... all voltage need posistive values.
Added after 2 hours 41 minutes:
this is my results of photodiode
Cumps
