Manni
Newbie
Hi everyone,
I want to design a DC/DC converter that can produce half-waves for a grid tie inverter. The nominal input voltage is 41V and the ouput power is about 400W. Output voltage is 250V RMS, so I need about 350V peak voltage. The targeted efficiency is 96% or higher. I have looked at various topologies, especially interleaved Flyback Converters, LLC Converters and the Push-Pull Converter. At this point I believe the best way to move forward is using a push-pull converter, but I am open for other suggestions! Is it possible to achieve the targeted efficiency of 96% with a push-pull converter and how do I need to design the transformer in order to achieve that?
Regards
Regards
