alsabri_badr7
Newbie
Motor Specifications:
For these voltage value and efficiency; should I use IGBT or MOSFET? Because I have read that IGBT is excellent for > 100 V (high voltages) but it is not that much in efficiency. I have done the calculations needed and it is attached below:
- Rated power: 50 kW
- Rated voltage: 200V DC
- Rated current: 250A
- Nominal voltage: 400V DC
- Capacity: 50 kWh
- Input Voltage Range: Specify the range (300V - 450V DC).
- Output Voltage and Current: Detail the required output voltage (200V DC) and current (250A).
- Efficiency and Ripple Voltage: State the efficiency (>95%) and ripple voltage (<2% of output voltage) requirements.
