danny davis
Banned
What is DC component?
At my work , they say DC component is the "TIME GAP" or " Cross over" section between the positive and negative cycles at the zero crossing point when you have a push pull network
Is this Time gap or Cross over called DC component?
If the DC component is not zero and is +5 volts. The Positive cycle will END at +5 volts not at zero volts? The Positive cycle should END at zero volts having zero DC component
