dc-blocking capacitor fro single-supply
Max01800
Junior Member level 3
In audio D amplifier, if they are in single-ended mode and they use a single-supply we need to use a DC-blocking capacitor. Otherwise we don't. Why is that?
To be able to generate positive and negative swing the PWM centers around 50% duty cycle, so you have some non zero DC voltage. This needs to be filtered with a capacitor.
In a dual supply the 50% duty cycle will Center around 0V and therefor no need for a capacitor.
An alternative is to attach a DC voltage to the 'loose' end of the load. Adjust amplitude so AC is balanced back-and-forth through the load.
Link below runs this schematic in Falstad's animated interactive simulator:
tinyurl.com/ytavjkem
Toggle full screen (under File Menu).
Volt level is adjustable via slider at right.
LaTeX Commands Quick-Menu:
