Dataloss error checking mechanism
tiwari.sachin
Full Member level 6
Full Member level 6
India
I am using a device that communicates to a mobile via bluetooth.
My unit has a MCU and bluetooth connected via UART
When there is continuous communication happening between the two devices, I see that there is some data loss. This happens randomly and I cannot really find a proper sequence for the same.
Works fine for longer duration for some mobiles and for some, the time of proper communication is different.
I was thinking of using CRC (384 bits and/or 576 bits followed by 16 bit CRC). Since there would be lot of computation that goes plus extra couple of bytes, the overall communication speed will drop drastically.
Is this the better way or are there other faster and good techniques to check proper data communication.
You should enclose the data pack within a protocol frame having a sequential number, so that you could determine exactly the ID for the lost packs, The glanularity of the pack would depend on the proportion of errors, so that you could choose some size which would not loose performance adding unecessarily check-data/processing.
Two most common problems are buffer overruns and EMI interference on RF such as Rician Fading. If you can eliminate these possible root causes, by any means, then we can work down a list of possible COMM issues
There is a machanism placed exactly on top of the bluetooth which is made of metal. Could this be the possible issue??
I have designed a new board and shall provide the details soon here. Kindly let me know if I am doing it right way. I shall post the link in a few minutes
Link for New PCB
https://www.edaboard.com/threads/355729/#post1521841
This post has details on bluetooth mounting on PCB
