database error while generating artwork using allegro16.3
Tamil Elakiya
Junior Member level 1
hi,
when i try to create an art file i got the data base error.
when i open this view log,db doc,i have attached those errors
Thank u
hi tamil,
first do one think tools-->database check select all and then run or else do update drc
now generate artwork if you get same problem start-->cadence-->product-->select pcb editor utilities in that select DB doctor select current board file as input file and select output file as same file and then click check .after that check viewlog (error will fix )
Do database check and update DRC before generating gerbers.
Once that is done you will be able to generate artwork.
