data type conversion in c++?
asic1984
Full Member level 5
Full Member level 5
hi
how can i convert a double value like 0.0567 to an array of char value to send it using the udp protocol (using c++)
thanks too much for your help
this is known as typecasting
answer=(int)fltnum;
the typecast will cause the value of fltnum to be converted to an integer value before being assigned to answer.
in your case
a = (char)i; // Treat i as a char and assign it to a
hi
thanks for your reply ,but conversion like a = (char)i;
will not be useful in case for example of double type which is 8 bytes while char is 1 byte .....in this case i need an array to store the value in as what i think
ex: double t=0.05642 this number will be converted to a char array of 6 elements
i tried that using poiters .but it didnot work
thanks for help
the C standard library has functions for that:
(Don't forget #include "stdio.h" )
sprintf is the one you're looking for:
float theValueToConvert;
char buffer[128];
sprintf(buffer, "%.6f", theValueToConvert);
(with the 6 in the format string, the number of digits behind the comma)
more information:
https://www.cplusplus.com/ref/cstdio/sprintf.html
Antharax
    asic1984
