engr_joni_ee
Advanced Member level 3
If two PCs are connected by serial cable having D Sub-9 connector then we can send data from one PC to the other PC provided if same Baud rate is used in Tera Term in both PCs.
Similarly, I am wondering how can we do this by Ethernet cable ?
I guess if both PCs have static IPv4 address then we can connect them through Telnet in Tera Term, and can send data from one PC to the other, right ?
The question is that most Windows PCs are connected to the Network through automatic IP address. Is that OK to change the automatic to static IP address ?
Secondly, please recommend a freely downloadable packet sender and receiver software which can also monitor the Network traffic.
